Hello masters of Light burn!
First time build, from scratch. This home made machine is an Eggbot/Smoothieboard/Laser Diode. The laser is not firing and I think its cause of my config file, do I need to put in an S value in somewhere (?). Can someone please review my config. I don’t believe this is a hard wire issue because I am able to test fire the laser using a physical toggle switch on the J Tech Photonics laser driver I am using.
thank you!
