Eje Y Láser btslaser
HOLA TENGO UN BSTLASER SERIES NO. 241022002 USO RDWORKS DE 130CM X 90 CM
USE EL EJE ROTATIVO Y CUANDO QUISE VOLVER AL USO HABITUAL SE DESCONFIGURO EL EJE Y AHORA SOLO LEE UNA FRACCION DE LOS 90 CM Y EL EJE Y ES MAS LENTO NECESITO RESTAURARLO DE FABRICA O QUE VUELVA A RECONOCER LOS PARAMETROS
Dice que llega a los 900 mm pero no es asi
HELLO, I HAVE A BSTLASER SERIES NO. 241022002 RDWORKS 130CM X 90CM
I USED THE ROTARY AXIS, AND WHEN I WANTED TO RETURN TO USUAL USE, THE AXIS WAS MISCUED. NOW IT ONLY READS A FRACTION OF 90CM, AND THE Y AXIS IS SLOWER. I NEED TO RESET IT TO FACTORY OR HAVE IT RECOGNIZE THE PARAMETERS AGAIN.
It says it reaches 900mm, but it doesn’t.
Did you undo what you did to set up the rotary? Not unchecking the rotary button is a common issue.
