Hola, buen dia a todos, me gustaria obtener de su gran apoyo y ayuda, tengo una maquina de grabado y corte laser CO2 de 50w, de 40x40cm, trabaja con corellaser, por eso su tarjeta ppal es una M2 nano, y quiero saber si puedo trabajar tranquilo con el software lightburn, sera compatible? de antemano, muchisimas gracias.
Hello, good morning everyone, I would like to get your great support and help, I have a 50w CO2 laser engraving and cutting machine, 40x40cm, it works with corellaser, that’s why your main card is an M2 nano, and I want to know if I can work safely with the lightburn software, will it be compatible? in advance, thank you very much.
No. LightBurn does not work with M2 Nano, at least not directly. I believe some people are using Meerk4t as an emulation layer in some cases.
Most people with these boards will replace them with compatible boards that can be used in LightBurn. Cohesion 3D, Mini Gerbil, Omtech K40+, and MKS DLC32 are all popular replacement boards. The first 3 are specifically made as K40 upgrade boards. Not sure how similar your laser would be to a typical K40 but must be fairly similar since they share the same board type.
Muchisimas gracias, es grato saber lo rapido que responde, ahora estoy mas claro, en lo sucesivo hare un upgrade de mi maquina, quisiera cambiarla por una que vi en un video en you-tube, es una placa controller grbl, y facilmente podria darle mejor uso al laser mas su pantalla tactil, espero pronto hacerlo, tal vez igual no sea compatible con el programa lightburn, pero le habre hecho una actualizacion que verdaderamente la hara trabajar mucho mejor. Igualmente muchas gracias por tomarse el tiempo, fuerte abrazo y saludos a la familia.
Thank you very much, it is nice to know how fast you respond, now I am clearer, in the future I will upgrade my machine, I would like to change it for one that I saw in a video on you-tube, it is a grbl controller board, and I could easily give it better use the laser plus its touch screen, I hope to do it soon, maybe it is not compatible with the lightburn program, but I will have made an update that will really make it work much better. Also thank you very much for taking the time, big hug and greetings to the family.
