90% of intermittent problems I see are due to poor grounding of the internal components, chassis, water receptacle, through to the earth pin.
The ground pin on a laser is for countries with primitive electrics, often only two-wire, in Asian and eastern-europan open-air workshops.
Educating people that having two earths is a bad idea, is also worthwhile.
Anyone can check and remedy earthing problems with a gas-station multimeter, or even a flashlight and a couple of bits of wire.
The easiest way is to unplug your mains lead from the wall, leaving it plugged in the back.
If you’ve just been using the machine, turn it off and give it a minute to discharge itself before fiddling around. There’s very little chance of any problems, but a capacitor in a psu can give you a shock if you’re not careful, so best to wait a minute and be safe.
First check the centre pin of your power cable with the chassis. A screw or bolt is a good place to check. If you’ve got a good connection (less than 0.001 ohm/ bright flashlight bulb) then go on to check every ground on the psu’s, controllers, etc. against the chassis.
If you find a device or connector has a poor connection, undo it, clean around it and, if necessary, scrape a bit of paint away - a Dremel or similar battery tool is very handy - clean it and redo and retest.
I’ve found some machines to have many, many bad grounds. Don’t assume if you find one it’s fixed. I view it as ‘where there’s one…’
The cause of poor earths can be: the connector; the wire to connector interface; poor mechanical connection to a chassis skin; poor mechanical crimping of the connector; incorrect termination (yes, 5V - 24V through the chassis. Doesn’t really break anything, but it causes havoc, especially when intermittent.)
You need to pay particular attention to your high tension lines from the LPSU to the tube. You definitely don’t want any chance of an earth on the pre-ionisation side. Plenty of silicone and shrink-wrap. fire it up in the dark - any leakage of current will show as sparkly mini lightning. That’s bad. You can hurt yourself or your machine if HT goes to ground.
