Do any of you have this limit switch board, mounted and running with Lightburn? I have big problems in the configuration because when I set the origin in the program at the top right (where the switches are installed) the motors go backwards and when I go to fix them so that they turn straight, I find that moving the machine correctly I move towards the negative, that is, outside the work area. Can any of you to this correctly configured add-on card, can post the Settings to me?
