Hi
hi I have eleksmaker mega … with grbl 1.1 firmware … which setting you have to make, and how … 255 or 1000 it is 30 or 32
Hi
$30 is the setting you’re asking about. The number doesn’t matter much, as long as both LightBurn and GRBL agree on what it is.
Edit > Device Settings, then S-Value Max is the LightBurn setting, and $30 is the GRBL one.
and can you tell me how I see what is set now?
and $ 30 is the GRBL one. … where is this setting?
Oz is showing the ‘Basic Settings’ tab on the 'Device Settings page exposed by clicking the ‘spanner/screwdriver’ icon found near the top-center of LightBurn main screen.
my problem was / is that I didn’t know that you have to put 2x $$ into the console so that I can see the values of what grbl 1.1 has
So is $ 30 = 255 that important? and how can i set it to 1000?
Grbl 1.1e [’$’ for help]
Type $30=1000 in the console then press enter.
Working from any “console” type interface to your firmware settings can be weird and takes time to become comfortable using this approach. LightBurn provides a different interface to these firmware settings by selecting ‘Edit’→’Machine Settings’. This interface might be a bit easier to review and adjust as needed. That is our intent anyway.
Here is what all these firmware settings mean: https://github.com/gnea/grbl/wiki/Grbl-v1.1-Configuration
On GRBL, you can also use Edit > Machine Settings to view and modify the settings in a UI instead of the console, and the settings are described there (a little).
super thank you all! got it
