Enable $J Jogging
In the past with Enable $J for Jogging, when using the Move Command menu, when long holding the direction buttons (Up, Down, Left, Right) the jog would move the laser head until released. With the upgrade to 1.4.05 the command seems to no longer be functional?
My laser is an Atezr 35w +.
Thank you,
Barry Cook
Do you also have “Continuous Jog” enabled in Move window?
Yes I do. I have checked Enable $J Jogging.
That’s a different setting in Edit->Device Settings.
What I’m referring to is in Move window. there is a separate toggle for “Continuous Jog” located beneath the jogging controls.
Dah! Continuous Jog is now switched to on. It works as advertised.
Thank you so much!
Barry Cook
