I cannot get the rotary attachment to work properly while having the enable rotary setting enabled. It stretches the image out if I do not use the enable rotary setting. If I do use the enable rotary setting the laser does not do anything. I can adjust the rotary turning radius by using the test button.
This is a blue and white chinese laser with a Rudia RDC6445G(EC) controller. I did search the form but none of the suggestions worked.
