I was cutting a few projects and one cut completed perfectly but the very next cut, the tip of my laser beam started wiggling. I’m not entirely for sure why. Can anyone help?
The machine will work all mechanical connection lose over time. You need to setup a maintenance schedule to clean/check you machine.
I do it about every two weeks, unless I see some kind of anomaly.
Take hold of it, power off, and move it around to see where it’s lose…
Not all of these heads are built alike, so you will have to figure out what part is lose.
The lens can be lose inside the tube also… this goes for any mirror also.
If you have more difficulties, explain what you are doing and what the expected and real results are…
Good luck
I had this problem on my K40.
Popped in an O-Ring and problem solved.
Jim
