Looking for documentation or what settings others are using. Specifically, the S Max Value. I’ve seen some use 255 and other use 1000. Also noticed the firmware was limiting max X and Max Y to 300 and was only able to increase to 600. What range of speeds are you using?
I was using 1000 because it is a 32-bit controller and because the GCODE generated by the Creality Print tool uses 1000.
so how do i determine what value I should use? When I use Creality Print (the Vendors software) i see this in the GCODE. Does this mean i should be using 1000?
G92 X0 Y0 Z0
G90
G0 F3000
G1 F1500
M3 I
G0X70.667Y73.222
G0X147.999Y73.222
G1S999
G0X70.666Y162.888
G1X70.777S999
G0X108.300Y74.533
M3 S1000
Yes, that is what I believe and have had the best success with.
