Ender 3 S1 with 1.6W Laser
Hello,
I use a Creality 3 S1 Printer with a Creality 1.6W Laser.
The Settings work fine with the Inline Mode and Prindmode “fill”
But once I set “line” the laser only burns the first line. The other lines are only moved with no laser power.
The M3/M5 mode and M106/M107 modes are both not working.
May I have the wrong start gcode?
Does anybody habe an idea?
Is it possible the power is being reduced to the point of cutting out due to inline reducing power to accommodate the deceleration? Could you increase power or increase speed to force power higher?
I am having the same problem and I put the power to 100%
I think I figured it out. I had to enable the Fire option in the menus then I set it to 20% and it worked, it made a nice cut in card stock
