Lordalex
(Alexander)
January 18, 2023, 6:46pm
1
Hello @all ,
i changed the mobo from my K40 laser and installed the MKS DLC32.
Axis are moving and laser is working if i start a job. The only thing thats not working after the change are the endstops.
This are my settings:
Auf Verbindung warten…
ok
[VER:1.1.2022010701:]
[OPT:MPHSW]
[MSG:Using machine:MKS DLC32]
[MSG:Mode=STA:SSID=F 2GHZR:Status=Connected:IP=192.168.178.66:MAC=24-D7-EB-8C-DF-00]
ok
$0=10
$1=5
$2=0
$3=0
$4=0
$5=1
$6=0
$10=3
$11=0.010
$12=0.002
$13=0
$20=0
$21=0
$22=0
$23=3
$24=50.000
$25=635.000
$26=250.000
$27=1.000
$28=1000.000
$30=900.000
$31=0.000
$32=1
$38=1
$37=1
$40=1
$100=157.380
$101=157.380
$102=80.000
$103=100.000
$104=100.000
$105=100.000
$110=6000.000
$111=6000.000
$112=6000.000
$113=1000.000
$114=1000.000
$115=1000.000
$120=500.000
$121=500.000
$122=500.000
$123=200.000
$124=200.000
$125=200.000
$130=285.000
$131=272.000
$132=80.000
$133=300.000
$134=300.000
$135=300.000
ok
and this is how i connected my endstops. Tried with Signal and GND on NC (was the original connection) and also tried with SIGNAL and NO.
Also tried to change the Value $5. If its 0, the homing wont start and i get an error. If i change it tot 1, the homing cyclus starts, but nothing happens if i reach the endstops and motors are still running till i power the system off.
dont know whats the error. Even tried to change $20 to 22 with other values, but no luck.
Wrong connection?
berainlb
(PY)
January 18, 2023, 6:56pm
2
What specific limit switches are you using? If unsure, can you take a clear photo of it?
jkwilborn
(Jack Wilborn)
January 18, 2023, 7:02pm
3
For $23 to work, it requires that you have limit switches enabled… Setting any of these to 1 enables that operation.
$20 soft limits
$21 for Hard limits
$22 Homing cycle enable
You’ve effective covered up where/what you have blue and black wired, it appears to ground.
What kind of switch do you have? NO or NC?
Generally a NO switch is used, and it’s wired to ground. When active, the ‘signal’ input is pulled low (to ground).
A NC is opposite, as it breaks the connection when active.
I believe you have an incorrect schematic…
Lordalex
(Alexander)
January 18, 2023, 7:33pm
4
I have the og endstops connected in my k40. The original cables runs from C and NC. Like shown above.
But even with C and NO its not working
jkwilborn
(Jack Wilborn)
January 18, 2023, 7:54pm
5
I can’t help you if you don’t answer my basic questions about the device.
Do you have a NO or NC switch?
Lordalex
(Alexander)
January 18, 2023, 8:56pm
6
I guess nc, cause that was the regular connection
jkwilborn
(Jack Wilborn)
January 18, 2023, 9:13pm
7
Lordalex:
I guess nc
No guessing … wiring is different depending on the switch type…
Without this, I am not sure how I can help…
do you have a voltmeter?
can you post a picture (or link) to the switch?
Lordalex
(Alexander)
January 19, 2023, 5:23am
8
I had the endstops in my hands and saw the description on the pins, so thats all what i say. Cables were running to pin described as C and NC.
Ill check the connectivity with the voltmeter if im at home.
But like i said, i tried both pins.
jkwilborn
(Jack Wilborn)
January 19, 2023, 9:24pm
9
You can’t use both no and nc switches together or simultaneously.
Even if you have it wired right there are other configuration options that might have an effect on how the switches are read.
You need to find out the technical part of it so we can ensure it’s wired right, before we look elsewhere.
Lordalex
(Alexander)
January 20, 2023, 10:08am
10
I dont use them at athe same time. Like i said i tried it with both versions. None of them were working, thats why i was asking.
What configuration do you mean if its connected right?
jkwilborn
(Jack Wilborn)
January 20, 2023, 3:07pm
11
Your drawing specifically shows both in use…
Your configuration says you have NC switches
Lordalex:
$5=1
Let me clarify what you are attempting to do…
The input to the controller for the limit can be configured (via $5 setting) to be either pulled low from a high state (NO type switch $5=0) or it can be pulled high from a low state (NC type switch $5=1).
If you follow the schematic on the side of the switch, it shows which is the NC/NO connections.
Most of these machines use the NO type for a pull down operation.
Wire the common (one side) of the switch to ground, the NO connection goes to the controllers input. You will have to change $5 to 0.
This is the most simple…
Can you try that?
system
(system)
Closed
February 19, 2023, 3:08pm
12
