I cannot burn an “image” or a “fill” within 10mm of the left hand side of my machine. I can cut a “line” but not the other two options. It says “engrave beyond size” It is the only thing I am trying to burn I am using a AWC 708 controller? If anyone has a thought I would appreciate it.
That’s your controller telling you it doesn’t have enough room for the deceleration / overshoot. Lower the speed, or (if you know what you’re doing) increase the acceleration for scanning to reduce the amount of overshoot required.
