hi everyone i am new here so hoping someone can help me, i am wanting to engrave a png file
on my mantech 500x300 80 watt laser,could anyone advise on any settings
thanks
That’s not possible at all. It depends on your material, picture size and quality, your personal requirements. You need to test, test, test.
Maybe this helps as well:
Engraving a PNG on your laser sounds like a neat project. Before diving in, it’s wise to check your PNG file’s size. Large files can sometimes slow down the engraving process. You might want to consider compressing it using tools like compress jpeg. This ensures smoother engraving and faster results. Now, onto the settings. Since you’re new to this, experimentation is key. Start with a lower power and speed setting to avoid damaging your material. Gradually increase these parameters until you achieve the desired depth and clarity. Also, don’t forget to adjust the resolution settings to maintain image quality.
