Engrave then cut out image
How do I engrave part of an image then cut the outside out. For example I want make some dominos so I want to engrave the dots and then cut out the dominos from a piece of beechwood
…any suggestions???
Set the outside box of your domino to a different layer then setup your speed and power differently from you first layer. example if you’re engraving at 100mm/s and power of 20% on layer 1 then layer 2 will be say 50mm/s at 80%. Just an example!!!
As Brad said ^^
Like this
