While using laser at Makerspace, I was wondering what would happen if I selected “Negative Image” in Cut Settings Editor. I entered my settings in File Notes option before saving. I just opened my file at home and “Negative Image” is no longer highlighted; and, my other settings don’t match the settings I saved at Makerspace.
You likely don’t have the same LightBurn config / preference files on those two computers, so the defaults don’t match.
If that’s the only laser you use, then you could copy their settings to your PC:
Copying your settings to their PC might be a Bad Idea™.
