I believe the machine has limit switch inputs for each axis. And when I press the home button it gives me the “Homing cycle is not enabled”, because I left it off when I setup the device for now.
If the machine replies with “homing cycle is not enabled” that would be a configuration issue in the firmware itself, not within LightBurn. Until it’s been zero’d you’ll have no way of absolute positioning the machine. You can zero manually by powering up the controller with the laser head in the front-left position (or wherever your origin is, but front-left is the most common).
