after i load an image into lightburn it looks normal and correct.
After I click play it shows the image as normal output.
However when I click Start and the image is engraved onto a piece of wood the image is a mirror image.
Am I missing a setting somewhere.
This is a new Xtool D1 I just bought and setup. Did I make a mistake somewhere in the setup?
[quote=“carrolldan, post:1, topic:74769”]
Possibly. Is origin set to top-left in Edit->Device Settings? If not, then it should be.
I’m guessing you didn’t use the .lbdev file provided by xTool to setup your laser. Check here:
User Manual for xTool D1 LightBurn Software – xTool
