The screen is right side or correct side and then the laser engraves in mirror or backwards.
how can i fix this discrepancy or aberration, is it the software or the machine, i am still on the 30 day trial on lightburn and thinking the software is not worth buying, good thing i tested it before buying.
The software is very much worth buying. Some of the best laser software on the market in my opinion. As to your mirror issue, you have your origin set incorrectly. It’s in Edit/Device Settings. Assuming your machine has homing switches, the origin is the corner that the machine homes to upon startup. If it doesn’t have homing switches, you’d likely set to the opposite corner that you have selected.
Fixed it, thank You
