Engraving 50 lines on a tumbler with rotary
I’m back. Don’t worry, lots of stuff. Please confirm your rotary is working, go back to rotary screen, enable rotary, and hit test.
Rotary should rotate exactly 360 degrees.
EDIT: Your setup shows rotary in the X direction, is this correct ?
Went down to the shop. Ran the same exercise you are looking for. Maybe spun it backwards.
I’ll post a video in a sec
Rotary settings. Rotary I’m using is 38400 Microsteps per revolution
50 increments
10 increments, variable text and extension tails, start 0, advance 5 every 36 degrees
2 minute video:
https://firearm-videos.sixguns.com/channel/Albroswift/video/40/win_20250105_11_33_05_pro
Link to article:
https://masters.lasereverything.net/posts/rotational-repeat-marking-with-variable-text
No RUSH Al,
So I am at 6400 steps/rot, the max I can go is 25600
When I click test the rotary turns clockwise 1 turn, stops and then turns on the other direction ans returns to zero.
AL YOU’RE AMAZING
That works excepted for the numbers.
dd is engraved? If I change “dd” by “0”, the 0 is engraved
What did I forget?
Thanks so much
Patrice
So it’s not understanding you want variable text. I select serial number. Highlight the dd and click that.
If 6400 rotates the chuck 360 degrees, that is the correct setting. You would have to change dip switches inside the laser on the microstep driver if you want something different. 6400 is fine.
Al, you are really amazing.
Everything works perfectly.
In FRANCE a proverb says this:
It is better to have one who knows than 100 who seek.
6400 rotates the chuck 360 deg, I’ve made a test with 25600, the chuck was spinning maybe 50 turns one way then in the other direction.
I returned to 6400.
If I want it engraves I must disable in this window “enable rotary”.
I had also to change the axis from x to y
Then I adjust the angles on every layer for engraving and I click on “start”
I’ll try next time to engrave the 3 layers at the same time.
It works perfectly.
Thank you so much
Now I only have to adjust the engraving parameters.
When one knows, it’s so easy.
I wish you a good day.
Best regards
Patrice
Hello every one.
I finally could engrave what I wanted.
Thanks so much to Al for his help, pretty appreciated.
my first successful vernier engraving
nice work for only 1-2 weeks laser experiance
Thanks my friend
Thanks for showing finished creation. Looks very professional.
Thanks Al
Still learning
have a good day
