Engraving Borosilicate glass, can it be done on K40?
Can you engrave borosilicate glass?
I’ve engraved borosilicate glass, which is used on my 3D printer bed. The printer design requires magnets to be epoxied into place on the underside. I felt I’d get better grip on an engraved surface, and the magnets I had available were too thick by a bit more than a millimeter.
I set an appropriate size circle to fill and gradually increased the power until I could get a good “burn.” I also brushed a water/detergent mixture on the surface, to keep the glass cool (it gets HOT) and to keep the fragmenting glass somewhat under control.
The surface over the 5 or 6 mm diameter circle was more or less a grid with miniscule variations in depth and the epoxy bonded quite well.
Well I have some borosilicate mugs I’m trying to engrave. So I’ll experiment with distance from the head to get a good burn plus the power setting
