I have lightburn. I am trying to engrave a brass name plate. Need to know what settings to use. Currently I am getting no image to appear. Can you help
Visible light lasers don’t work too well with metals…
I’d think this is probably unlikely that you will be able to do much with metals … You’re best option is likely some kind of coating you can lase to the metal… Even that, may be a problem with only 5W.
Good luck
Brass is typically 70% copper, which is a very good heat conductor like aluminum.
I did some 0.010" brass, using it for arrows on the machines column… I could tell … had to add some more power to get it to cut…
Copper pans are considered the best for cooking because of coppers heat conductivity.
