I am trying to trace a detailed image to engrave. It is a fire department emblem, and VERY DETAILED. Any hints I getting the trace feature to actually trace the image accurately?
This is an example of the image (if you can see it). When I trace it cuts off the eagle head on the center medallion and just looks like a “Blob”. Any help is appreciated. Thank you
What are you engraving on?
A light or dark material? (What will happen with the dark background?)
What size is the final output?
Do you intend to reproduce/engrave every element of the graphic?
These intentionally low res black and white versions will help you to visualise the graphic in a different way that may help you to see problematic areas as well as potential solutions for them.
I know I didn’t specifically address your question about tracing, but without knowing exactly what you want the laser to achieve - it’s very difficult to suggest the best tracing strategy (if tracing is needed).
