Can anyone suggest a fix my engraving its coming out about 10mm larger than planned. For example the engraved logo is 51mm wide but the size on screen is 41mm. Im using a 50w JPT Mactron, Ive just installed Lightburn after using ezcad (no issue before switching)
Thanks in advance
When you made the device in Lightburn, did you import the EZCad file that came with your device?
That should have your lens setting in it… I think it’s called, on mine, markcfg7…
