Engraving, how to prevent laser from jumping from right to left
Hi, how should I configure LightBurn to engrave large shapes, like frames and titles, without jumping from one side of work area to the other?
This will save a lot of the engraving time.
Thanks,
If this is an Image you may be limited to Raster (left-right) engraving.
If this work is constructed as a series of vector shapes you will have access to different fill options. In which case Offset-fill may prevent much of the wasted motion. I would avoid Flood-Fill for intricate patterns and letters as it was designed to fill large rectangular areas quickly.
A capture of the Cuts / Layers window will likely inform us of your process.
Hi, well, this frame is not constructed as a series of vectors, which as I understand can give me to ability to engrave one afte another. I thought that there is a way to engrave it without this jumping. Thanks.
