Engraving Image
Doesn’t seem like you’re focused … drop it down a little and see what that does… also, what’s your low power setting at? 40w is plenty, maybe double my original power and run same speed … do an offset fill?
Just looked up your laser. Seems it’s a 5.5W diode. Not sure what they mean by 40W machine “output”, I’d guess they mean total power consumption but I could be wrong.
I drop down my laser and put almost the same speed and power as your file and it starts to look really good. I need to do more test to be sure but its the best i did so far. Thank you so so much!!!
Laurie - you could probably benefit from doing a Ramp Test to find your focus point. There are some great explanations and videos out there that do a much better of explaining/showing than I can. I did a ramp test for my XTool and found the sweet spot was a little different from the drop-down focus device, so I cut a piece of wood to that height for repeatability.
One thing I’m noticing is your laser is configured with the wrong device type. It’s configured as GRBL-M3. It should almost certainly be GRBL.
  1. Push “Devices” button in Laser window.
  2. Click on name of your laser
  3. Push Edit button
  4. Change device type to ‘GRBL’
  5. Push next through wizard until complete
This should provide for better power control.
