HI Can anyone help a newbie when engraving this image for my own use the laser isn;t clear on the word Alone, Please help In Lamans terms Printing Onto Slate Using The AtomStack a5 PRO its on a level surface
I’ve heard of an effect like this caused by oil (or other substance) on the surface diffusing the light. Did you acetone the slate before lasing?
Side note: I’ve never engraved on stone and it could be your picture quality, but you might want to do some test runs with a higher DPI/lines per inch to get a more solid engrave. Ignore if this was intended!
Thanks so much for the input Aaron
