Engraving .jpg Pictures
Been using Lightburn and laser engraving for a couple of years now. Pretty comfortable with doing engraving on wood, glass, tile now. But engraving jpg photos seems to have eluded me. Tried a few times and not very good results. Wonder if anyone would be willing to share an engraving file with me where they have successfully engraved a jpg photo so i could look at the settings.
There are some very popular video tutorials available for processing images, I linked some of them here: Specific guides - Diode Laser Wiki
Not very likely it would be the same for you as it was for me. Lots of variables:
  1. Glaze on tile
  2. Tile color under glaze
  3. Moisture content of tile
  4. image quality
  5. Laser characteristics
  6. Tile coating used
  7. Tile coating application
  8. How much patience you have
  9. Whether or not a UFO is in the area
Images are the most difficult thing you can do with a laser. It involves a lot of trial and error. What I have not noticed is a difference between file types, like JPG, BMP, TIFF, and so on.
The link @misken provided is a superb place to start. My favorite are the 2 videos with the pretty girl in them.
I don´t think a file will help you improving your picture engraving. However I can highly recommend the first 2 videos in the Wiki, @misken posted, about finetuning the dpi.
I went 254 dpi on all my projects (wood, slate, glass etc.).
For a simple fill it is still a great setting but for a dither pattern it was way to high dpi, cause the scanlines were overlapping and the dither pattern was not good at all.
What helped me?
Establish a workflow with a focus block, so the hight from the surface to the laser is always the same.
Lowering dpi + dot width correction.
It required a lot of fine tuning for each material.
For my 30W diode:
Wood ~ 150 dpi
Slate & coated Glas ~ 200 dpi
Coated Aluminum ~ 225 dpi
And as @MikeyH stated, every change in your workflow e.g. coating used, how you apply the coating, change of supplier for base materials or even a different batch from the same supplier… can have an impact on your finetuned settings.
