Engraving output differences PC to MAC
I’ve typically used a PC to run out thunder at work. I decided to try it out on my MacBook and found that I cannot get the same output results. When using my mac, “FILL” doesn’t really work - it ends up being sort of filled and sort of lined. To narrow down where the problem was I used the same file on both the PC and the Mac sending to the Thunder Laser one after the other with no changes to the settings or to the laser. Here is the output – I assume I have missed a setting in my new mac set up? Suggestions? Thank you!!
Sent from Mac
From Windows
Hopefully, you can see in these images how different the output is.
Settings:
From Mac
From Windows
Hi Shannon
Question:
Are you sure both Edit > Device settings match?
I think you might have missed the scan offsets on your Mac.
If you are on 1.6.0 or higher you can try the Bundles to migrate your settings across correctly
Thank you! This was the issue and everything is working as expected again :slight_smile:
