Engraving reversed
I loaded a file into my AtomStack Swift 7W and it had a “text” name in the design. When I ran the file it engraved and filled nicely. I then loaded the same file into Lightburn and ran it but for some reason the name engraved reversed (like in a mirror). I used the mirror tool and it engraved the right way but the rest of the engraving was a little bit messy. Why would that happen
Welcome Chris.
Did you setup your device origin correctly?
Read the following doc;
If you loaded the device profile from the QR code in the manual, your device origin should already be correct.
Here’s a direct link to the .LBDEV
If that was already correct, we’d need to know exactly which file you “loaded into the Atomstack” and how.
All fixed thank you.
