i am new to “Lasers” and I got a Orthur Laser Master 2, it works and I get him connected to Lightburn.
I started some “test engravings” the word “Hallo”. The Problem (see the picture)is that a the lower part from all letters are missing. this happens all the Time. Some one had in Idea what I can do/change?
Thanks for the Info.
I will check but I don’t think the problem are the belts. The rest of the engraving ist goog it’s only the Start (First 2 or 3 lines) and it seems the laser is not „strong enough“ here.
Try engraving on darker material. White paper reflects most of the power from a visible light laser, and it won’t burn until it heats up enough to darken it, and then the darker area absorbs more power and burns very quickly.
