I having issues while engraving. My laser was working fine while I was engraving a design on wood cutting boards, then it started to stop mid stream. Now it burns a little and then stops
Ricky
Are your/it’s cable connectors firmly seated. Is your USB cable of good quality.
Is there any drag/pulling on cables while laser is in operation.
Does it always stop at the same place or after a certain amount of time.
Are there any ‘error’ messages in the console.
Can you run the job directly from controller to bypass any possible USB cable issues.
