I am trying to make an engraving file that cuts two of the same data plate at once. What I dont understand is that to cut one plate when oriented vertically takes 59 min, but when I try to cut two (both oriented vertically) it takes not 2 hrs but 3 hrs, see below:
Why is this? It seem odd
Another related issue I am having is that I cannot set the speed any higher than 70 mm/s when I orient my plates vertically (so I can fit 2). When I set it any higher than 70 my machine spits back "need more overshooting or larger acceleration”. I think this is because my engraving is 288mm tall and my bed working area is only 300mm tall. Is this accurate? Can I not cut at full speed if what I am cutting takes up the extent of the working area? Any help is appreciated, I am trying to speed up the process of making these plates.
One_example.lbrn2 (586.5 KB)
Two_example.lbrn2 (1.1 MB)
