It’s my first time trying out the Cross-hatch option for engraving with Lightburn on my Aeon Mira (Ruida controller) and I’m having some issues I can not resolve on my own.
When the option is turned ON the first cross-hatch pass has a depth of more than 1mm (power set to 20% speed of 900mm/s, same as for normaln non cross-hatch engraving). With the same settings without the option turned ON I get a perfect engraving on acrylic… Any help solving my issue would be appreciated
The settings (power & speed) don’t effect the outcome at all if cross-hatch is ON (enabled). Even on low/high power low/high speed I get engravings going as deep as 1mm on the first pass (ie. from left to right…)
Even if you’re able to get 1200 mm/s along the X-axis there’s no way you’re getting that along the Y-axis. The controller should reduce power to accommodate the slower speed but that will depend on the min power set.
