Equivalent to Xtool S1 mark processing area
Hi
is it possible to show the material area on the screen (mark processing area) to help locate the components to be cut, as I can with xtool studio?
This feature is incredibly useful and I would really like to access it in Lightroom
Draw a square around the outline of the design. Then mark the cut layer for it as a Tool so it will not engrave. The Tool Layer would be T1 or T2
Thanks - i really meant tracing the material area by moving the laser by hand to the corners, pressing a button, and then it shows in the main processing window
That wont work that i know of. If you move the laser by hand it forgets where its at. You may be able to do what you want by changing from “Absolute Coordinates” to “Current Position”. You may get an out of bounds message but if your sure your project will fit on the bed you can ignore that. You cant do all four corners but you can manually set the laser to one corner, im thinking bottom left but i could be wrong, then hit Frame. I dont think the processing window will show the correct position but it may
