playing with the Trace tool. Awesome!
2 questions:
- Is there an erase tool to clean up trash from the Trace?
- Is there a centerline Trace?
2 questions:
You can un-group the result, and then just drag or click select stuff you don’t want, press the Delete key to remove things. You can also use Node Edit mode:
Point the cursor at that tool button and press F1 to see the list of keys for doing the various node operations.
No centerline trace at this time.
