Been struggling with a design recently . It required the trimming of a circular path. I had some success with the break apart function although you seemingly have little control of the break function and where it breaks . Also adding nodes changes the shape of the section and the curved shape of this particular design is important. All I needed was a trim function or eraser tool preferably. The only option I could do was export, edit and then import again. Anyone got any work around a please as this has cropped up a few times for me now .
Adding nodes shouldn’t change the shape. Can you show an example of where it did?
Break function works only on nodes - Insert a node where you want to break the shape, and then break it there. I don’t have a Trim tool yet, but it is planned.
I will give that ago and try and get an example up for you to see also. So are you stating that if I place two nodes on the circle then break apart I can delete in-between the two nodes .
