Erasing portions of circles
In he design process, when we have created a circle as a part of the design, how do we erase a portion of that circle ?
  • Select the circle
  • Edit → Convert to path
  • Start the Edit Nodes tool
  • Add & delete nodes or arcs as desired
When you delete a node, you get an arc connecting the nodes on either side.
When you delete an arc, you get two end nodes.
There are other options to remove a portion of the circle.
Because it’s a closed shape you can use the boolean operations and subtract other shapes from a circle.
What is your circle ‘up against’ that you want to remove a portion?
There may be a really elegant solution for this.
Thank you so much, for that !!!
I was just shy of going for a bigger hammer :crazy_face:
Blessings,
Bill
Hey John,
From time to time, I get requests for specialized wooden commemorative coins that will require a portion of the circle to be the cut line and other parts are just part of the whole design…
In that case I would need to break the continuous line into segments…
Thanks for the input…
Blessings,
Bill
“Never underestimate the power of a measured response!"
