Carriage movements are erratic and sometimes won’t work at all, either in continuous or single movement. Using latest LB version connected to custom router\laser setup, Keyestudio .09 board. My question is this. I can open a file in LB, save the gcode, run the file in Open Builds and the carriage reacts perfectly in both modes, continuous or single movement. Once I get the carriage in the right spot
in LB the file will run perfectly, it’s the preliminary motions that refuse to cooperate, I’m at my wit’s end trying to figure this out, I have tried several different USB cables, mice, etc. and nothing changes, also have tried changing the port speed to no avail.
