Erro22 after inicialize software
I’ve read some topics I searched on the same subject but haven’t found a solution yet.
I don’t know if it’s related, but it happened after I created some “macros” to lock and unlock the motors.
Whenever I start the software (V2.0.05), the “Speed” field in the “move” window appears as 0. I have to enter a value for the desired speed, otherwise I get error 22.
(error:22
Feed rate has not yet been set or is undefined.)
What could be the cause? Was some parameter on the board changed?
Here are the parameters:
$0=10
$1=0
$2=0
$3=3
$4=0
$5=1
$6=0
$10=1
$11=0.010
$12=0.002
$13=0
$20=0
$21=1
$22=1
$23=3
$24=100.000
$25=4000.000
$26=250.000
$27=2.000
$28=1000.000
$30=1000.000
$31=0.000
$32=1
$38=1
$40=1
$100=79.616
$101=79.612
$102=80.000
$103=100.000
$104=100.000
$105=100.000
$110=6000.000
$111=6000.000
$112=6000.000
$113=1000.000
$114=1000.000
$115=1000.000
$120=2000.000
$121=2000.000
$122=500.000
$123=200.000
$124=200.000
$125=200.000
$130=365.000
$131=320.000
$132=80.000
$133=300.000
$134=300.000
$135=300.000
ok
This is a reported issue and ls nothing you are doing wrong. Sometimes it remembers the setting, and sometimes it goes to zero.
I have not seen a report on what causes it yet.
And sometimes reinstalling the software solves it.
I just haven’t wanted to bother reinstalling it and then loading all the preferences yet. :grin:
That’s the only thing I haven’t done yet. Because turning off and restarting the software, even with the controller board, doesn’t solve it.
I haven’t tried starting the software twice (having two Lightburn windows active), and switching the connection to the card alternately… but think the result will be the same.
I have not tried that, but the “sometimes” is another clue. The real problem is that it is not repeatable, yet. If we knew what made it happen, then the developers would have something to focus on.
I’m unsure if I didn’t make myself clear or if I lost the context in the translation. What I meant to say is that reinstalling the software might solve the problem, but I haven’t tried it yet. I will try it, probably next weekend.
Logically, if we know what’s causing the problem, and how to “work around” it, we should inform the programmers so that measures can be taken. :+1:
