… shoot the cat, then check if the machine is physically ok and the endstops are still where they should be. You move your laser manually to x = 0 Y = 0 and turn on power, the error should not be there any more. You may need to reset the errors, find the appropriate code for it, e.g. Grbl v1.1 Interface · gnea/grbl Wiki · GitHub
