sys: Ortur Laser Maser 2 Pro (20w) System had been working fine. started swapping back and forth with Ortur rotary roller. Now, It gives me an ALARM:2 I enter S# then press enter in my console. This messages comes up; error:2
Numeric value format is not valid or missing an expected value.
Try this
In console
type
$RST=*
press enter
Then tap reset and reboot machine
Once back type
$i in console and post output please?
I entered in the code you gave me, before shutting down the system I hit home and frame and it finally moved. thank you
Do tell me results of $i please
you might need a firmware update
error:2
<Idle|MPos:-397.000,-397.000,0.000|Bf:99,1023|FS:0,0|Pn:PS|CL:0,100|PS:2,1|ER:0,0|VA:23614,0|Ov:100,100,100|A:S>
ok
Starting stream
[MSG:Pgm End]
Stream completed in 0:00
<Idle|MPos:-347.000,-397.000,0.000|Bf:99,1024|FS:0,0|Pn:PS|CL:0,100|PS:2,1|ER:0,0|VA:23604,0|WCO:0.000,0.000,0.000|A:S>
ok
[GC:G1 G54 G17 G20 G90 G94 G49 G98 G50 M5 M9 T0 F5993 S0.]
Starting stream
[MSG:Pgm End]
<Idle|MPos:-297.000,-397.000,0.000|Bf:99,1024|FS:0,0|Pn:PS|CL:0,100|PS:2,1|ER:0,0|VA:23590,0|WCO:0.000,0.000,0.000|A:S>
ok
Starting stream
[MSG:Pgm End]
<Idle|MPos:-247.000,-397.000,0.000|Bf:99,1023|FS:0,0|Pn:PS|CL:0,100|PS:2,1|ER:0,0|VA:23586,0|WCO:0.000,0.000,0.000|A:S>
ok
Starting stream
[MSG:Pgm End]
<Idle|MPos:-247.000,-347.000,0.000|Bf:99,1023|FS:0,0|Pn:PS|CL:0,100|PS:2,1|ER:0,0|VA:23590,0|WCO:0.000,0.000,0.000|A:S>
ok
Starting stream
[MSG:Pgm End]
<Idle|MPos:-247.000,-297.000,0.000|Bf:99,1024|FS:0,0|Pn:PS|CL:0,100|PS:2,1|ER:0,0|VA:23576,0|WCO:0.000,0.000,0.000|A:S>
ok
Starting stream
[MSG:Pgm End]
<Idle|MPos:-247.000,-247.000,0.000|Bf:99,1024|FS:0,0|Pn:PS|CL:0,100|PS:2,1|ER:0,0|VA:23586,0|WCO:0.000,0.000,0.000|A:S>
ok
Starting stream
[MSG:Pgm End]
ok
<Idle|MPos:-397.000,-397.000,0.000|Bf:99,1024|FS:0,0|Pn:PS|CL:0,100|PS:2,1|ER:0,0|VA:23614,0|WCO:0.000,0.000,0.000|A:S|H:1>
ok
Starting stream
ALARM:2
G-code motion target exceeds machine travel. Machine position safely retained. Alarm may be unlocked. (Right-click the βDevicesβ button to reset the connection)
On or near line 2:
[MSG:Reset to continue]
ok
Ortur Laser Master 2 Pro S2 Ready!
OLF 180.
[MSG: Flame detector active,Ambient infrared value:0]
Grbl 1.1f [β$β for help]
[MSG:β$Hβ|β$Xβ to unlock]
[MSG:Caution: Unlocked]
ok
$RST=*
[MSG:Restoring defaults]
ok
OLF 180.
ok
<Idle|MPos:0.000,0.000,0.000|Bf:99,1024|FS:0,0|Pn:PS|CL:0,100|PS:2,1|ER:0,0|VA:23600,0|Ov:100,100,100|A:S|H:1,7>
ok
[GC:G0 G54 G17 G21 G90 G94 G49 G98 G50 M5 M9 T0 F0 S0.]
Starting stream
error:8
Grbl β$β command cannot be used unless Grbl is IDLE. Ensures smooth operation during a job.
<Idle|MPos:137.962,171.263,0.000|Bf:99,1024|FS:0,0|Pn:PS|CL:0,100|PS:2,1|ER:0,0|VA:23586,0>
ok
Starting stream
Starting stream
Layer C
Stream completed in 0:01
ALARM:3
Reset while in motion. Grbl cannot guarantee position. Lost steps are likely. Re-homing is highly recommended.
ok
OLF 180.
ok
ALARM:6
Homing fail. Reset during active homing cycle.
ok
[MSG:Emergency switch Engaged!]
OLF 180.
error:18
[MSG: Emergency Switch Engaged.]
[MSG:No Power Supply! Check TroubleShooting Section in User Manual.]
[MSG:Power Supplied]
[MSG:Emergency switch Cleared.]
Port failed to open - already in use?
OLF 180.
[MSG:Detecting ambient infrared]
error:9
G-code locked out during alarm or jog state.
ok
Homing
[ORIGIN: China]
[PRODUCER: ORTUR]
[AUTHOR: ORTUR]
[MODEL: Ortur Laser Master 2 Pro S2]
[OLF: 180]
[DATE:11:15:52 - Aug 25 2021]
[VER:1.1f(ESP32).20210403:]
[OPT:VNMZHSL,99,1024,3]
Target buffer size found
ok
ok
ok
ok
ok
ok
ok
ok
ok
[ORIGIN: China]
[PRODUCER: ORTUR]
[AUTHOR: ORTUR]
[OLF: 180]
ok
Homing
ok
<Idle|MPos:0.000,0.000,0.000|Bf:99,1023|FS:0,0|Pn:PS|CL:0,100|PS:2,1|ER:0,0|VA:23576,0|Ov:100,100,100|A:S|H:1,7>
ok
Starting stream
Job halted
OLF 180.
ok
<Idle|MPos:0.000,0.000,0.000|Bf:99,1024|FS:0,0|Pn:PS|CL:0,100|PS:2,1|ER:0,0|VA:23548,0|Ov:100,100,100|A:S>
ok
Starting stream
ok
Starting stream
Layer C
Stream completed in 0:02
ALARM:3
ok
OLF 180.
ok
ALARM:6
ok
OLF 180.
error:18
OLF 180.
error:9
error:18
Homing
[ORIGIN: China]
[PRODUCER: ORTUR]
[AUTHOR: ORTUR]
[OLF: 180]
ok
error:18
Waiting for connectionβ¦
[ORIGIN: China]
[PRODUCER: ORTUR]
[AUTHOR: ORTUR]
[OLF: 180]
ok
Homing
error:18
[ORIGIN: China]
[PRODUCER: ORTUR]
[AUTHOR: ORTUR]
[OLF: 180]
ok
Homing
error:18
[ORIGIN: China]
[PRODUCER: ORTUR]
[AUTHOR: ORTUR]
[OLF: 180]
ok
Homing
ok
Starting stream
Layer C
[MSG:Pgm End]
Stream completed in 0:16
<Idle|MPos:0.000,0.000,0.000|Bf:99,1024|FS:0,0|Pn:PS|CL:0,100|PS:2,1|ER:0,0|VA:23516,0|WCO:0.000,0.000,0.000|Ov:100,100,100|A:S|H:1,7>
ok
[GC:G1 G54 G17 G20 G90 G94 G49 G98 G50 M5 M9 T0 F799 S0.]
Starting stream
Stream completed in 0:04
<Idle|MPos:123.625,182.725,0.000|Bf:99,1023|FS:0,0|Pn:PS|CL:0,100|PS:2,1|ER:0,0|VA:23464,0|A:S>
[GC:G0 G54 G17 G20 G90 G94 G49 G98 G50 M5 M9 T0 F5993 S10.]
ok
Starting stream
Stream completed in 0:03
<Idle|MPos:123.625,182.725,0.000|Bf:99,1024|FS:0,0|Pn:PS|CL:0,100|PS:2,1|ER:0,0|VA:23450,0|A:S>
ok
Starting stream
<Idle|MPos:134.725,166.400,0.000|Bf:99,1023|FS:0,0|Pn:PS|CL:0,100|PS:2,1|ER:0,0|VA:23478,0|A:S>
ok
Starting stream
<Idle|MPos:134.725,166.400,0.000|Bf:99,1023|FS:0,0|Pn:PS|CL:0,100|PS:2,1|ER:0,0|VA:23460,0>
ok
Starting stream
<Idle|MPos:134.725,166.400,0.000|Bf:99,1024|FS:0,0|Pn:PS|CL:0,100|PS:2,1|ER:0,0|VA:23478,0|A:S>
ok
Starting stream
<Idle|MPos:137.988,171.625,0.000|Bf:99,1024|FS:0,0|Pn:PS|CL:0,100|PS:2,1|ER:0,0|VA:23488,0>
ok
Starting stream
<Idle|MPos:137.988,171.625,0.000|Bf:99,1024|FS:0,0|Pn:PS|CL:0,100|PS:2,1|ER:0,0|VA:23464,0|A:S>
ok
Starting stream
Starting stream
Layer C
Stream completed in 0:28
ALARM:3
ok
OLF 180.
ok
<Idle|MPos:169.875,173.212,0.000|Bf:99,1024|FS:0,0|Pn:PS|CL:0,100|PS:2,1|ER:0,0|VA:23450,0|Ov:100,100,100|A:S>
ok
Starting stream
ok
$RST=*
ok
OLF 180.
<Idle|MPos:0.000,0.000,0.000|Bf:99,1024|FS:0,0|Pn:PS|CL:0,100|PS:2,1|ER:0,0|VA:23502,0|Ov:100,100,100|A:S>
ok
Starting stream
sorry. Too much
$RST=*
ok
OLF 180.
ok
Starting stream
1.8 firmware
You are running a quite old firmware try this file
Download, unzip and follow PDF instructions when you have a chance
https://ortur.tech/firmware/OLM_Series/OLM2_PRO_S2_Firmware_Release_1.87.zip
Thank you, sir. I appreciate your help.
