gwschuck
(Chuck Bell)
1
I’m a 1st time user of lightburn and am having a problem getting started. Below is the error 20 fault I get when I try to start the job:
error:20
Unsupported or invalid g-code command found in block.
On or near line 0:
Job halted
Stream completed in 0:00
I am running lightburn on a windows 10 platform and my laser is a Atomstack S20 Pro. I would appreciate any help you can provide.
berainlb
(PY)
3
Take a look through this Topic. A couple of common scenarios that cause this. See if this applies to you:
Efrenmtz
(Marlon Efren Martinez Gutierrez )
4
Hola tengo el mismo problema, empieza dura 5 segundos y se detiene.
error:20
Se encontró un comando de código g no admitido o no válido en el bloque.
En o cerca de la línea 3:
El trabajo se detuvo
Transmisión completada en 0:01
ok
ok
ok
ok
ok
ok
<Idle|MPos:28.863,8.875,0.000|FS:0,0|Ov:100,100,100>
ok
Comenzando transmisión
Transmisión completada en 0:00
Layer C02 Pass 1 of 4
Layer C02 Pass 2 of 4
Layer C02 Pass 3 of 4
Layer C02 Pass 4 of 4
error:20
ok
ok
ok
ok
ok
ok
Grbl 1.1h [‘$’ for help]
error:20
ok
ok
ok
ok
ok
berainlb
(PY)
5
Post gcode please. Also, if you haven’t read it the linked post above covers many common causes for this.
system
(system)
Closed
6
