Every time I try to engrave I get error 20.
Unsupported or invalid g-code command found in block.
On or near line 2:
Moves fine and frames fine.
using mks dlc32 board.
Any help is appreciated.
On or near line 2:
Make sure you’ve selected GRBL
as the device type, rather than the more exotic choices.
It may require the DTR
option:
There are apparently subtle problems depending on the controller’s GRBL version:
If fiddling around with those variables doesn’t get it running, let us know what happened.
I have tried everything I can find online and while different settings appear to fix other people’s problems, I keep getting the same error. I will check what version GRBL I have tonight.
I had no luck so have installed an older version of the firmware and it all seems to work perfectly
Is it possible you had g-code clustering enabled in Edit->Device Settings? That’s only available on certain controllers and would cause an error if had this set.
