I think it’s likely that either one of these two conditions is present:
You have gcode clustering enabled on laser not supporting this. You don’t list your specific model but I believe this is only currently supported on OLM3 for Ortur models.
Your device is not configured with the right device profile. You can check this by pushing Devices button in Laser window. Then click on the name of your laser. It should list “GRBL” on the lower left of that screen. If it’s any other variant then Edit your device and change the type to GRBL.
Changing from M7 to M8 things have started working. Thanks very much for your help. I’ll need to confirm ortur as the latest firmware i installed they told me to set to M7
