Error: 20 unsupported or invalid g code found in block
When I simply try to run my laser. I found that I get the error: 20 unsupported or invalid g code found in block. Anything I can do to resolve this?
Can you push “Save gcode” in Laser window and save to a file with .txt extension? Then upload file here for review.
Laser Test.txt (6.0 KB)
You’ve configured your device using iLaser profile. Edit your device by pushing Devices button in Laser window. Switch profile to GRBL.
You’re using a relatively old version of LightBurn. If you were to the latest version your laser should have been identified immediately as GRBL.
