Error:24 Two G-code commands that both require the use of the XYZ axis words were detected in the block. On or near line 374:
how do i fix this lasergbrl works but not light burn
Without knowing more about either the file or your laser, verify GRBL is the device type, rather than any other GRBL variation.
laser #1 Ortur Laser Master 2 S2-SF
laser #2 ORTUR Laser Master 2 S2 LF,
any jpeg or png image
both have the same error
Another clue!
Make sure Enable G-Code Clustering is turned off (in Edit → Device Settings).
sorry but im unable to find it can you send me a snapshot?
Two lines above the Finish Position text input boxes.
This may be due to a communication issue as well.
Can you use File->Save gcode, then save with a .txt extension and then upload the file here? Please do this with the same design that created the error with “On or near line 374”.
markpat69 and I have the same Error 24 problem. And I gather from this short thread…the same problem understanding the recommendations made so far. My issue started a couple days ago. I’ve tried all the usual 101 fixes, including re-plugging my USB link and re-booting everything. The Error 24 has halted my job intermittently and unpredictably. I’m running an Ortur LM2, 10w. Thanks.
