Hi I am using a CNC 3018. The machine refuses to respond to any command from lightburn and inside laserGRBL the status moves from idle to jog when I press the arrows on the software but the machine stands still.
I am unsure if it a hardware or software issue. I have followed advice from other posts but no luck with some G-code troubleshooting.
(No limit switches are on the 3018, I’ve disabled homing to try but no luck also)
Waiting for connection…
Grbl 1.1f [’$’ for help]
ok
[VER:1.1f.20170801:]
[OPT:V,15,128]
Target buffer size found
ok
ok
[OPT:V,15,128]
ok
Homing
error:5
Homing cycle is not enabled in your Grbl settings.
Error 5 appears that you had shut off the homing option in Grbl 1.1f but not in LightBurn. When you have two processors and it can be a challenge to get them talking to each other.
