Error:7 EEPROM read failed. Reset and restored to default values
error:7
EEPROM read failed. Reset and restored to default values.
Please tell me what has happend here?
It cuts for a while then stoppes at a random place. Everytime adifferent place.
Worked fine Last week now it keeps doing this…
I have a Atomstack A5 20w laser
There’s usually a command in the Console window or another error before the Error 7 reset.
Please copy-paste the Error 7 and the previous dozen or so lines from the Console window into a reply here. This may be the best way to see what happened.
Thank you…
I figured out that it was a power problem on my laptop.
The power cable (Charger cable) stopped working and my battery was on power saving mode…
SO that made the usb port cut out every time I was doing a job. That’s also why it was random every time.
  1. *I used a new cable (Charger cable)
  2. And I disabled my USB settings in Advanced Power settings.
Problem Solved…For now.
After everything i tried and failed…i cant believe that that was the reason. lol
Works well now.
Lee.E
Will do that when something happens again… Thank you.
Some of the Laptop USB ports have a yellow color coded insert in them. Yellow is ‘always on’ for charging but i’ve found it useful for when laptops try to snooze. You can also adjust your screen-saver or power management settings to avoid this.
Glad you found it!
