Hi. need help/
Plotter with servo on axis z, after connecting error 152 or alarm 9, tried different configurations, error only in lightborn, lasergrbl, Openbuild connects and works fine. after connecting to openbuild, homing it works fine with lightborn until the next time it is turned on.
[MSG:RST]
[MSG:INFO: FluidNC v3.9.4 GitHub - bdring/FluidNC: The next generation of motion control firmware]
[MSG:INFO: Compiled with ESP32 SDK:v4.4.7-dirty]
[MSG:INFO: Local filesystem type is littlefs]
[MSG:INFO: Configuration file:Plotter3.yaml]
[MSG:ERR: gpio.32 - Pin is already used.]
[MSG:ERR: Configuration error at /machine/Laser: ]
[MSG:INFO: Machine PenPlotter_A0]
[MSG:INFO: Board MKS-DLC32 V2.1]
[MSG:INFO: UART1 Tx:gpio.18 Rx:gpio.23 RTS:NO_PIN Baud:115200]
[MSG:INFO: I2SO BCK:gpio.16 WS:gpio.17 DATA:gpio.21Min Pulse:2us]
[MSG:INFO: SPI SCK:gpio.14 MOSI:gpio.13 MISO:gpio.12]
[MSG:INFO: SD Card cs_pin:gpio.15 detect:gpio.39 freq:8000000]
[MSG:INFO: Stepping:I2S_STATIC Pulse:2us Dsbl Delay:0us Dir Delay:1us Idle Delay:255ms]
[MSG:INFO: Axis count 3]
[MSG:INFO: Shared stepper disable I2SO.0]
[MSG:INFO: Axis X (0.000,1000.000)]
[MSG:INFO: Motor0]
[MSG:INFO: stepstick Step:I2SO.1 Dir:I2SO.2 Disable:NO_PIN]
[MSG:INFO: X Neg Limit gpio.36:low]
[MSG:INFO: Axis Y (0.000,1000.000)]
[MSG:INFO: Motor0]
[MSG:INFO: stepstick Step:I2SO.5 Dir:I2SO.6 Disable:NO_PIN]
[MSG:INFO: Y Neg Limit gpio.35:low]
[MSG:INFO: Axis Z (-5.000,0.000)]
[MSG:INFO: Motor0]
[MSG:INFO: rc_servo Pin:gpio.22 Pulse Len(1000,2000 period:1048575)]
[MSG:INFO: Update timer for rc_servo at 20 ms]
[MSG:INFO: Motor1]
[MSG:INFO: Kinematic system: Cartesian]
[MSG:INFO: STA SSID is not set]
[MSG:INFO: AP SSID FluidNC IP 192.168.0.1 mask 255.255.255.0 channel 1]
[MSG:INFO: AP started]
[MSG:INFO: WiFi on]
[MSG:INFO: Captive Portal Started]
[MSG:INFO: HTTP started on port 80]
[MSG:INFO: Telnet started on port 23]
Grbl 3.9 [FluidNC v3.9.4 (wifi) ‘$’ for help]
[MSG:ERR: Configuration is invalid. Check boot messages for ERR’s.]
[VER:3.9 FluidNC v3.9.4:]
[OPT:PHS]
[MSG:Machine: PenPlotter_A0]
[MSG:Mode=AP:SSID=FluidNC:IP=192.168.0.1:MAC=C8-2E-18-9A-63-19]
ok
Waiting for connection…
[OPT:PHS]
ok
error:152
error:152
